Fuel Injectors
Old Jan 14, 2008 | 04:16 PM
Gage2502's Avatar
Gage2502
Fuel Injectors
Im going to bring my 2000 Expy in for spark plugs, fuel filter change, coolent change, should I have the injectors cleaned?
Also how about a front end alignment?
Thanks ~Gage~
My Expy has 83000 mile on it, its a 5.4 V8
Did I miss anything?
Old Jan 14, 2008 | 06:43 PM
Modified 99's Avatar
Modified 99
I change the plugs in my 99, 5.4 in about 8 hours (first time) at 145K. I used an after market injector/carb cleaner at about 97% of my fuel fills. Haven't had an injector problem EVER.
Old Jan 14, 2008 | 08:18 PM
madsonp's Avatar
madsonp
If it's running fine I wouldn't mess with the injectors, if anything add a can of Sea Foam to your gas the next time you fill up. I do this about once every 6 months to mine to help keep the injectors clean.
Old Jan 14, 2008 | 08:26 PM
madsonp's Avatar
madsonp
As far as the alignment, I'd say if it goes down the road stright (i.e. doesn't pull to the left or right) and your steering wheel is centered when going stright and your tires a wearing evenly, I don't think I'd worry about that either. Like they say, if it ain't broke don't fix it.
Old Jan 15, 2008 | 02:01 PM
Gage2502's Avatar
Gage2502
Thanks guys for the info.
~Gage~
