98 Explorer crank sensor
Old Jan 14, 2008 | 07:39 PM
savage2211's Avatar
savage2211
It has a miss all the time. Are you thinking the head is cracked? Not loseing any fluids.
Old Jan 14, 2008 | 07:49 PM
antony25's Avatar
antony25
You also need to check that the injector is pulsing and not stuck on by using a noid light with the engine running. The light should blink fast and not be on steady.To check for a crack you need to use a borescope to look inside the cylinder.
Old Jan 14, 2008 | 07:55 PM
savage2211's Avatar
savage2211
ok. I will have to take it somewhere for that.......Thanks man
Old Feb 25, 2008 | 08:56 PM
savage2211's Avatar
savage2211
Well guys its fixed.... EGR was cloged up. Cleaned it and runs great now....Thanks guys
