boost gauge
Old Jan 14, 2008 | 07:49 AM
badblueoval4life's Avatar
badblueoval4life
boost gauge
installed gauges on my 02 7.3 my boost gauge not working i need pics of were to hook it in at thanks in advance
Old Jan 14, 2008 | 09:05 AM
badblueoval4life
k nobody got pics then just tell me
Old Jan 14, 2008 | 09:34 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You are saying its not working. Is it hooked up and still not working?
Old Jan 14, 2008 | 09:52 AM
bdrummonds's Avatar
bdrummonds
Look in my gallery at pic #24(I think), Now the brass plug on the spider pipe is where my boost guage is currently drawing from. Before I made the AIH delete fitting, I had a T in the map line (rubber hose that comes from bottom of spider pipe to the map sensor)
Old Jan 14, 2008 | 09:58 AM
miller_feed
Brandon, He says he installed the boost gauge and it is not working. I know when I installed mine and cranked the truck it didn't work, I pushed the pedal down and still no boost. I told my brother that was helping me that we will deal with this later and took the truck for a drive. The boost gauge started reading boost. So I was wondering if this is the same issue I had.
Old Jan 14, 2008 | 10:30 AM
bdrummonds's Avatar
bdrummonds
DOH!! I didnt read enough. Might want to loosen the fittings that go form the T to the guage(it is really easy to crush the small boost hose with the compression fittings)
Old Jan 14, 2008 | 10:48 AM
badblueoval4life
thanks brandon and rick i beleve ive got it hooked up wrong were is the map sensor i think i know but not sure ?
Old Jan 14, 2008 | 10:56 AM
ron's power stroke's Avatar
ron's power stroke
the dial to the left is my OBA..it sits right on top of the map sensor..if you fallow the red lines on my truck..(yours will be black) you can see where the map line goes..also you can see how my boost gauge is hooked up in this pic.
you can not make any boost with truck parked..you need to have a load on the truck...
Old Jan 14, 2008 | 10:58 AM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
Here you go, http://www.dieselmanor.com/diy/PSD3-gauge/image23.htm
miller_feed, I did the same thing, I freeked out thinking I screwed up, especially when I hit the throttle and nothing happened.
Then the tranny gauge had me concerned, till I took a long drive.
Old Jan 14, 2008 | 11:08 AM
miller_feed
Yeah, Dave, I was so pissed that it didn't work. Heck, no one ever said it will only make boost under load. But I was so happy to see boost during the ride.
Old Jan 14, 2008 | 11:12 AM
TurtleRacing
PSD Addict
I guess ya get this preconceived notion on how things will work, then there's reallity
I figured, hit the gas, turbo spins, makes boost, apparently not! But there's nothing like that feeling of spending all day doing something, in the cold, get finished and think it doesn't work. The only thing better than that is when you go for a drive and the needle jumps!
Old Jan 14, 2008 | 01:08 PM
badblueoval4life
wher did u guys tap in for the tranny temp.
Old Jan 14, 2008 | 01:12 PM
TurtleRacing
PSD Addict
There's a port on the drivers side of the tranny, take the plug out and put the sensor in there.
Diesel Manor has awesome directions for installing gauges.
http://www.dieselmanor.com/diy/PSD3-...73gauge-p1.htm
Old Jan 14, 2008 | 01:14 PM
miller_feed
Right here. http://www.dieselmanor.com/diy/PSD3-gauge/image15.htm
Old Jan 14, 2008 | 01:16 PM
miller_feed
Darn Dave, You type to fast. lol
