Hole Pattern on wheels?
Old Jan 13, 2008 | 02:21 PM
RUSTY50F1's Avatar
RUSTY50F1
Is the hole pattern on a 5x4 1/2 on a ford wheel the same as a 5x4 1/2 chevy. I am looking for a set of slotted mags for my 50f1. It has a 78 Jag IFS, and IRS under it. Any one know what will fit. They are 5x4 1/2. Will ford and chevy both sit it. Thanks.
Old Jan 13, 2008 | 02:26 PM
RUSTY50F1's Avatar
RUSTY50F1
This is the # on Ebay of the wheels.
http://cgi.ebay.com/ebaymotors/AMERI...QQcmdZViewItem
Old Jan 13, 2008 | 02:44 PM
Brian_B's Avatar
Brian_B
No clue Rusty. I have never been near a jag at all. I avoid chebies if at all possible.
I would almost bet that the center hole (for the hub) is different between ford and cheby, even if they bolt pattern is the same.
I thought the small cheby one was like 5 X 4 3/4 though.
Look the jag (chevy and small ford) up on tire rack.com. They list sizes and bolt patterns.
Old Jan 13, 2008 | 03:11 PM
thendrix's Avatar
thendrix
As far as the 5 x 4 1\2 it should be the same. What that means is 5 holes in a 4 1\2 inch diameter circle. Now the holes may be a different or the mounting surface may be different but the bolt pattern should be the same.
Old Jan 13, 2008 | 05:50 PM
4tl8ford's Avatar
4tl8ford
The Bolt circle x X x.x has to be the same, it's a math thing.
The difference's are in the dimension of the center circle.
Google "bolt circle"+wheel
Someplace will have a list of compatable wheels by size and make.
Honest, would I ____ you?
Old Jan 13, 2008 | 06:47 PM
rdemilt's Avatar
rdemilt
I dont know about your situation but Chevy used 5 on 4.75 bolt pattern
Rick
Old Jan 13, 2008 | 10:53 PM
RUSTY50F1's Avatar
RUSTY50F1
I got it straight; I was measuring from center to center. Not edge to center. I need 5x4 3/4. Thanks
Old Jan 13, 2008 | 11:05 PM
4tl8ford's Avatar
4tl8ford
Don't forget that center circle.
Old Jan 13, 2008 | 11:12 PM
RUSTY50F1's Avatar
RUSTY50F1
Your right center is 2-1/4 on mine. Thanks
Old Jan 14, 2008 | 06:40 AM
49willard's Avatar
49willard
Rusty, I am in the process of fitting up wheels and tires. I am using Vintique gennie wheels thru Summit. The wheel openings are slightly larger on the wheels than needed for the jag (they clear just fine). I may machine up a couple of rings to fit the wheel tighter to the jag .
Old Jan 14, 2008 | 07:55 AM
cmoritz's Avatar
cmoritz
HEY rusty, Here are some thoughts ,Do you have a used wheel /tire shop near you ? maybe put a deposit down on a couple of different " known " units on fo size? #2 what does the aftmkt offer for JAGS ?,#3 Use Dykem ,a machinist"s dye on the back of wheel mating surface , then torque to spec"s ..inspect wheel hub and wheel ,there"s always the custom wheel route..Looking Good ..keep those wheels turing ..Good Luck!!
Old Jan 14, 2008 | 11:13 AM
thendrix's Avatar
thendrix
I don't think Dykem is what you are talking about. Dykem is a layout die that dries relatively fast and allows you to scribe lines and be able to see them. I think what you are talking about is what people call bearing blue. I think the correct name for it is pression blue. It is a blue paste that doesn't dry for a while after applied. What you do is paint on a thin layer then put the two surfaces together. Anywhere the pression blue has been "mashed" that is a high spot.
I think it is kinda hard to find. I have found it in one parts place around here.
And remember to use it sparingly. This stuff will get all over everything and turn anything blue.
Old Jan 15, 2008 | 06:27 PM
rhopper's Avatar
rhopper
Rusty, the bolt pattern on the jag is 5 on 4 3/4. Actually, it's 5 on 120mm, but what's .02 inches between us? For mock up, I'm currently using s-10 wheels, which have a center bore that's too small for the jag front hub. I had to enlarge it slightly. There shouldn't be any trouble with custom wheels, which have a larger center bore so they fit everything.
Old Jan 15, 2008 | 07:15 PM
RUSTY50F1's Avatar
RUSTY50F1
Thanks fellas; I have a set of early 60s Aluminum slot mag wheels. Fronts are 14x5 and the rear are 15x10. But My son-in-law can only find one of the rear wheels so I'm trying to find a match, with no luck yet. They are 5x4 3/4 hole pattern so they will work if I can find a match to the back one.
Old Jan 15, 2008 | 07:18 PM
RUSTY50F1's Avatar
RUSTY50F1
49willard; Do you have a pic of the wheels your using?
