Help Big Problem
Old Jan 13, 2008 | 10:46 AM
mike330's Avatar
mike330
Help Big Problem
I was just changing the rear shocks on my 96 f150 and the upper shock bolt just snapped off at the threads. NOW WHAT??? Does this stud come off or what?
PLEASE HELP
Old Jan 13, 2008 | 11:26 AM
Archion's Avatar
Archion
Veteran: Marine Corps
I dont know on 96, but on my 86 it is a welded stud. Maybe someone else has a better idea on it.
Old Jan 13, 2008 | 12:45 PM
sbishop's Avatar
sbishop
if I recall, that upper shock holder is riveted to the frame, probably will have to drill out the river and bold up a new one. my 84 same thing happen i'm sure I got a replacement from the junk yard off a 96
Sbishop
Old Jan 13, 2008 | 01:08 PM
Franklin2's Avatar
Franklin2
I am surprised your whole bracket is not rusted off. It's very common, and I bet the Ford dealer has the new bracket in stock. They had the rear spring frame bracket in stock for about $40.00 when that rusted off on my old 1980.
Old Jan 13, 2008 | 09:48 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
One of my shock mounts rotted off. Bronco Graveyard has um for $15. They are easy to remove with the bed off! Grind the heads off the rivets (on the outside of the frame rail) and pound them out.
Old Jan 14, 2008 | 07:41 AM
mike330's Avatar
mike330
I guess its not as bad as I thought , Thanks guys.
