Sponsored by: Real Truck
axle windup?
Old Jan 13, 2008 | 10:23 AM
propane's Avatar
propane
axle windup?
I know this is not a 6.4 question, but it is what pulls it. I have 08 f350 srw REAL box cc non fx4 Lariet. It also has the camper special, 18" wheels. The trailer is a 38.5 foot Cherokee Wolf Pack toyhauler. Dry wheight is 11500, ave loaded is 14500 (105 gal of water alone). What i am experiencing is severe tire shake moving from stop. Even with the trailer mt (11500). Has anyone have this problem? my dealer thinks it's the diff, but it does this from a straight pull from a traffic light. Even with the few problems i have had ( rad, belt, air filter, keyless entry) this truck I love to drive, yeah, i,m Blue.
Old Jan 13, 2008 | 11:29 AM
Maxium4x4's Avatar
Maxium4x4
What hitch set up do you use?
Old Jan 13, 2008 | 12:43 PM
redford's Avatar
redford
FTE Leadership Emeritus
Do you have a limited slip rear differential?
Old Jan 13, 2008 | 06:29 PM
oltrucker's Avatar
oltrucker
you hve to lift your foot an bit. my 6. dually would spin the rears on take off with 1000 lb tongue weight. these diesel have lots of low end grunt. if you dont believe me, try getting on it hard, then stop and look,,,im sure you will see some intereting rubber streaks.
Old Jan 17, 2008 | 09:06 PM
propane's Avatar
propane
yes it has ltd slip. its a fifth wheel with 2000# on the pin
Old Jan 17, 2008 | 09:07 PM
propane's Avatar
propane
it has limited slip
Old Jan 17, 2008 | 09:10 PM
propane's Avatar
propane
it has a limited slip diff. it also has an air pin box. 2000# on the pin. reese slider 15k.
