Electrical Question
Old Jan 13, 2008 | 12:04 AM
fireguy86's Avatar
fireguy86
Electrical Question
I have an 03 Ranger 4.0 4x4 XLT. I am wondering if anyone knows the output amperage of the alternator. I have heard everything from 90-110. I am running an all LED red lightbar with red grille lights and dash light along with a siren. Will all these along with normal draw eventually wear out my alternator? I have also entertained the thought of a second battery. There isn't room to mount one, but maybe someone has some ideas. Thanks all!
Old Jan 13, 2008 | 12:59 AM
powerstroke6ltr's Avatar
powerstroke6ltr
Odyssey sells dry cell high cap batterys in very small cases... may look into that... It all depends package wise on the output of the alternator. Any additional load will shorten its life, how much?? hard to say. LEDS draw very little.
Old Jan 13, 2008 | 01:04 AM
fireguy86's Avatar
fireguy86
do you know much about the cost of the Oddyssey batteries? The other problem is size. I would have to mount it in the bed of the pick-up I think cause of the lack of room in the engine compartment. Thanks!
Old Jan 13, 2008 | 08:15 AM
Dan Robertson's Avatar
Dan Robertson
I have driven Police cruisers for the past 30 years. I am a Detective now and run an unmarked car. It is a "plain-Jane" Ford Taurus, not a Police package thus it has the stock alternator. I have had no electrical problems what so ever. When you start running wig wag head lights, strobes, hallogen flashing lights, sirens and 100 watt two way radios, etc all at the same time, then a high output alternator should be considered. LED's have a very small current draw.
Old Jan 13, 2008 | 09:01 PM
643NRK's Avatar
643NRK
Remember as Powerstroker said, LED's do not pull very much. As in, not much at all. Even at 12 volts, that light bar draws next to nothing. The other thing to take into account, are you running the lightbar every second the truck is running?? I doubt it. Try to keep from running down the battery too much, and you should be OK.
Old Jan 13, 2008 | 10:10 PM
fireguy86's Avatar
fireguy86
I know LEDs pull little amperage. Thats why i went with LEDs. The bar with the takedowns, alley lights, all the flashing lights, and arrow bar in back pull 11 amps. the siren pulls 4. the dash light and grille lights combined pull 3. 18 amps is a lot when I hear the truck pulls 80 on a 90 alternator. I always keep the truck running when the lights are going, like on scene.
Old Jan 13, 2008 | 10:38 PM
powerstroke6ltr
Your particular application calls for a 540 CC battery 12V BCI group number 59, base number 5522. The model is a PC1200LMJT running about $180 plus shipping. It is a deep cycle type and has an expected life span of 8-10 yrs, plus has a great reserve capacity. I have had no problems running a 500 watt stereo system for 4 yrs on a stock alternator and battery. That is on whenever the truck is... You could get a battery minder for peace of mind which will alert you of a battery which is going low... Overall, you aren't running too much yet in terms of amperage draw to justify a new alternator in my opinion...
