Lifter tap.........suggestions????
Old Jul 28, 2002 | 11:41 AM
DaveK1979's Avatar
DaveK1979
I seem to have developed a pronounced lifter tap on the left side of my engine. It's a 429 in a 79 F250. She was full of oil at the time, but I changed it immediately and added a heavier weight oil, a 15W-40 Syn-blend. It didn't seem to help though. . It only taps when cold, and five minutes after taking off, it goes away. Does anyone have any suggestions about what to do about this or what is causing it? Would any particular additive fix it, or does the valve cover need to come off and the rockers inspected?? Or could it be an oil pressure problem. I just have the stock guages right now, so I'm not sure exactly what the pressure is. Guages are my next purchase. Any help would be excellent.
Old Jul 29, 2002 | 01:54 AM
cjcathey2002's Avatar
cjcathey2002
see my reply in the 73-79 truck section. motor flush.
1977 F250 460
C6 Hedman Headers
Dual 40 series
edelbrock performer
holley 4150
msd 6a and blaster coil
Old Jul 29, 2002 | 11:42 AM
georgedavila's Avatar
georgedavila
If the motor flush doesn't fix it, you could have a lifter going south. Is the valve train pedestal or early (pre-72) rail type rocker arms? If you have the early rocker arms you can buy Crane or other locking nuts ($20) and adjust your lifter preload.
Old Jul 29, 2002 | 12:13 PM
jeffmoody's Avatar
jeffmoody
jonney_boy
1997 - 2003 F150
Mar 14, 2006 04:48 PM
edward327
Bronco II
Feb 20, 2004 05:25 PM
jpd
Jan 3, 2004 01:42 PM
DuckRyder
16
Aug 15, 2003 04:20 PM
DaveK1979
Jul 30, 2002 03:52 PM
