pass. side front brake not working??
Old Jan 12, 2008 | 09:22 PM
kent's f-350's Avatar
kent's f-350
hi all when i bought my truck the guy said it had new brakes, but my right front is not working, i bled the lines and don't know what to do other than change the caliper? also only 1 out of the 4 door power locks work?
thanks
Old Jan 12, 2008 | 09:51 PM
medhvac's Avatar
medhvac
llets bump this one!wish i could help but i think u have a brake problem!
Old Jan 12, 2008 | 10:22 PM
farmdad's Avatar
farmdad
On the brake problem, maybe the piston was jammed into the housing and isn't operating? While standing still you could firmly push the brake pedal to see if you can make the piston come loose. Depends on how many miles on the truck but it might just be better to replace the caliper rather than try to repair yours.
Old Jan 13, 2008 | 09:16 AM
kent's f-350
truck has 212,000 mi
Old Jan 13, 2008 | 10:01 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Time for a new caliper! They're not expensive, pretty easy to do at home and be done with it. That rig can't be much fun to drive with only 1 front brake operating. As for the door locks. Which switch is working? Or is it just one lock working? I have found with mine that the **** clearance in the door panel is so slight that a little bit of lube on the **** itself will free them up.
Old Jan 13, 2008 | 10:10 AM
PaysonPSD's Avatar
PaysonPSD
Door Lock Fix
Door locks fix see post #3 on this thread:http
https://www.ford-trucks.com/forums/4...cks-fixed.html
Old Jan 13, 2008 | 12:58 PM
magnum300's Avatar
magnum300
the brake problem is probably frozen slide pins, a common problem.
go to http://guzzle.rbmicro.com/index.html to see how to fix them., easier to put a new caliper in though
