Intake ?
Old Aug 4, 2002 | 01:40 AM
79F2504x4's Avatar
79F2504x4
Intake ?
Ok guys I think Im gunna try out the Weinand Stealth intake on my 460 and was wondering how much taller it is than the factory manifold. Anybody have this manifold on a 460 in a 78 or 79 truck with an open element air cleaner and no body lift. Theres probably nothing to worry about but it never hurts to check.
Thanks alot
Chase
1979 F-250 4x4
71 460 Holley650, MSD OFFROAD, L&L Headers
C6-B&M Transpack
Dana HD44Front/60Rear
35 inch Goodyear Implement Tires
4 inch Skyjacker System
Much more to come
[link:www.tarleton.edu/students/jwillms/ChasesOldFord.com|My Truck]
Old Aug 4, 2002 | 10:02 AM
Ford79's Avatar
Ford79
Intake ?
I have a Stealth on my 460. It's about 3" taller than a stock manifold. If you use a filter element that is only 3" tall, there should be no clearance problems. I have a 5" tall K&N and it won't clear the hood on my truck. I'm also using a drop base air cleaner.
Old Aug 4, 2002 | 12:07 PM
classic79's Avatar
classic79
Intake ?
I'm currently running the factory air cleaner housing w/ a 4" K&N so the lid sits up about an inch from the base, and also have a nitrous plate under the carb. Don't have any clearance problems yet, but it is getting close.
Chris
79 F-150 Lariat: Long-bed, 2wd, 460 (intake, headers, cam, early heads), C-6 (shift kit)
79 Mustang: 460 swap under way, balanced rotating assembly, forged pistons, truck rods, c-8 heads ported, Lunati solid lifter cam, more stuff...
98 Chevy Silverado ext. cab 4x4 (work truck)
95 Lexus SC300 (wife's baby)
Old Aug 5, 2002 | 12:37 AM
79F2504x4's Avatar
79F2504x4
Intake ?
One more question, the 8012 stealth is for square bore carbs correct. Im pretty sure it is.
Thanks
Chase
1979 F-250 4x4
C6-B&M Transpack
Much more to come
Old Aug 5, 2002 | 12:10 PM
ledgeclimber's Avatar
ledgeclimber
Intake ?
