Software instead of a dyno????
Old Jun 12, 2000 | 11:00 PM
bigsnag's Avatar
bigsnag
Has anyone tried the software from Motion? It is a simulation which allows you to pick your engine components and run it on your computer to see how much hp/torque you will make. It's supposed to allow you to match the components (intake, heads, compression, cams, etc.) of your engine better. Has anyone tried this? Specifically with "385" series motors. Was it even close? Is this thing for real? Thanks in advance.
Old Aug 6, 2002 | 11:15 PM
jjgarcia03's Avatar
jjgarcia03
Old Aug 10, 2002 | 12:45 AM
Big Bad 1Ton's Avatar
Big Bad 1Ton
I used desktop dyno for kicks. Was cool cause it showed the results of over caming or to big a carb, and all that other voodoo stuff. Aint got the money to build an engine to worry about a real dyno though
