tranny question
Old Jan 12, 2008 | 09:18 AM
red rock 78's Avatar
red rock 78
Question tranny question
I posted about a month ago about water leaking from my tailpipe.I started tearing down the motor and the problem appears to be on the drivers side. Warped head and a cracked piston and block damage not worth rebuilding. I found 2 351m blocks and 1 302 f.i. that can be converted to carb. but I don't know about motor mounts or if will bolt up to my tranny. 1978 f150 351m not sure of tranny type.
Old Jan 12, 2008 | 09:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
stay with the 351M if you want easy. the 302 will not bolt to your trans, and will require new mounts, and a few other odds and ends.
Old Jan 12, 2008 | 05:36 PM
masterbeavis's Avatar
masterbeavis
460, It should bolt up with minimal frustration. Do a search on it.
Old Jan 12, 2008 | 07:30 PM
tjc transport
i ain't rite
true, a 460 will bolt to the trans, but you will have to change the mounts, and maybe the cooling system also
Old Jan 13, 2008 | 09:04 AM
red rock 78
thanks guys for the feedback probably stay with 351m.
Old Jan 13, 2008 | 02:00 PM
masterbeavis
The cooling system does not need any modifications. If you have a tiny radiator, then yes a bigger one would be nice, but not necessary.
When I did my swap, I bought mounts, put the motor in, and enjoyed twice the power, and the same fuel economy. A 2WD has factory parts available for it, buy the towers/mounts out of the donor truck, they should sell them fairly cheap.
jumpmasterjk
16
Sep 8, 2009 07:42 AM
ftwelder
Engine Swaps
Aug 2, 2009 04:11 AM
theophage
Engine Swaps
Feb 11, 2006 08:50 PM
f100power
Jan 22, 2004 09:25 PM
fordguy76
Feb 5, 2002 07:27 PM
