oil pressure high
Old Jan 11, 2008 | 11:37 PM
toolbeltdiva's Avatar
toolbeltdiva
oil pressure high
HI I got a 90 F150 and just recently my oil pressure has gone up a little. It's always been dead center and now it's up a little higher. Is this something I should worry about or maybe what could be causing it. Any advice would be helpful..
Thank you
Old Jan 11, 2008 | 11:46 PM
95F350XL's Avatar
95F350XL
I know with my old engine in my F350 the longer i drove it, the higher it would get, like usually the longer you drive the lower it gets. Your guage might be acting up, or the pressure sender might be going as well. Did you do anything different lately?
Old Jan 12, 2008 | 12:17 AM
EPNCSU2006's Avatar
EPNCSU2006
The 90 trucks should be about the starting year for the oil pressure switch controlled gauge. As long as there is enough oil pressure to close the switch, the gauge will read the same place no matter what the pressure. Something in the circuit has changed resistance, causing the readout to show slightly higher, while in reality, the oil pressure itself is most likely the same as before.
Old Jan 12, 2008 | 10:50 AM
preppypyro's Avatar
preppypyro
Oddly enough man, mine did the same thing.
I just got my truck back from my father, I lent it to him for a few years. He ran 15-40 oil in there, and I switched it to 5-30.
Anyways long story short, the oil pressure was around the o on the gauge, and when I was driving it back on a fairly long trip, it was up just about over the m!
Im not complaining though, its nice to see the oil pressure up
Old Jan 12, 2008 | 05:05 PM
mhg's Avatar
mhg
your oil pressure is not up
the factory gauge is a fancy idiot light
when the pressure hits 7 psi the switch closes
and the gauge goes to the same place every time
the only way the gauge changes is if the voltage or
resistance changes
Old Jan 12, 2008 | 11:02 PM
toolbeltdiva
Thanks for all the comments. The engine was just re-built 2 years ago. If the gauge is maybe lying to me, Is there a way to tell in the future is the pressure is going up where it shouldn't be. Just don't want to have anymore engine problems. Thanks again.
Old Jan 13, 2008 | 08:04 AM
mhg's Avatar
mhg
get an aftermarket gauge
autometer is good
www.jegs.com
I would go ahead and install an accurate temp gauge also
this is th setup I run in my van
