adjusting valves?
Old Aug 17, 2002 | 01:38 AM
JoeyH's Avatar
JoeyH
adjusting valves?
ok this is a dumb question.. but... im rebuilding my 1968 429 thunderjet.. and I am wondering how do I adjust the valves? or do I ? do I just run the rockers all the way down or what do I do here???
thanks, Joey
Old Aug 17, 2002 | 08:16 AM
georgedavila's Avatar
georgedavila
adjusting valves?
It should have a non-adjustable valve train, where you just tighten down each nut on the stud holding the rocker arm to published torque values.
I'd suggest you consider purchasing a set of Crane or other locking nuts ($25, with an Allen set screw to hold the adjustment) so you can adjust lifter preload. You'll notice a big difference in performance and idle.
Old Aug 17, 2002 | 08:17 AM
qtrmiler's Avatar
qtrmiler
adjusting valves?
Run them down. SCJ's are the only ones adjustable... unless you want to change the studs & rockers.
Old Aug 17, 2002 | 09:21 AM
georgedavila
adjusting valves?
Changing to lock nuts make them adjustable and they work.
Old Aug 18, 2002 | 12:18 AM
merc460's Avatar
merc460
adjusting valves?
I think what George means is the 429 thunderjet came with screw in studs and rail rockers the studs where shouldered and you screwed the rocker arm down to the shoulder so there was no real adjustment Eric
Old Aug 18, 2002 | 08:09 PM
georgedavila
adjusting valves?
Thanks Eric. Those lock nuts, same thing as used on roller rockers, convert any of the stud/rail rocker heads to an ajustable valve train. Well worth the minimal cost.
Old Aug 18, 2002 | 10:27 PM
phantom429's Avatar
phantom429
adjusting valves?
