1978 - 1996 Big Bronco
rear window stuck down
Old Jan 11, 2008 | 01:40 PM
sumoboy's Avatar
sumoboy
Hi, guys. Haven't been here for awhile cuz my sons been away at college with the Bronc. We put the window down yesterday to open the tailgate, and when we were done moving, the window wouldn't go back up. I know theres some kind of microswitch on the inside tailgate handle, and I can hear some clicking inside the panel when the switch is activated. We took the interior access panel off, thinking the motor and regulator were on the inside part of the glass. Anyway, we checked the wiring enough to see that the motor is plugged in pretty solidly, and then tried to activate the window with the key switch. You can hear clicking from the area of the key, but no movement. Does anyone know if you can get the glass closed without the motor working, or any major surgery?
Old Jan 11, 2008 | 06:51 PM
82MustangGT's Avatar
82MustangGT
mine would do it push on the pass-side tail gate while pushing the up button thats what i had to do every time i rolled my window down
Old Jan 11, 2008 | 09:44 PM
Aciancio's Avatar
Aciancio
try pushing against the tailgate on the drivers side while someone holds the switch. There is a safety switch inside the driver side latch and if your strike bolt bushings are worn/missing it might not close the switch. I have found that is the most common problem with the rear window so start there and see what you find
Old Jan 12, 2008 | 12:19 AM
DCR's Avatar
DCR
slam tailgait shut and try with key. it worked for me. oh yea i think i sprayed some contact cleaner in it also, not sure what kind,it was several years ago. crs
Old Jan 12, 2008 | 01:28 AM
Surge08's Avatar
Surge08
saftey switch can be located on latch assembly's that was the problem with mine and ford no longer makes the harness to correct the issure.
Old Jan 12, 2008 | 11:10 AM
helirich's Avatar
helirich
If all else fails, unplug the motor and run 12V and ground jumper wires to it.
Old Jan 20, 2008 | 12:29 AM
Surge08's Avatar
Surge08
The color of the wires is red and yellow
