6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
View Poll Results: DPF-back Exhuast system, is it worth it?
Worth it
20.00%
Just pipe that will void warrenty for money
80.00%
Voters: 15. You may not vote on this poll
DPF back exhuast
Old Jan 11, 2008 | 01:32 PM
RedDragon777's Avatar
RedDragon777
DPF back exhuast
i ran across this while looking for a system i saw on deisel world for my father in laws 7.3L. it is a new product for the 08 that does not need you to get rid of the DPF for it to work. My question is do you think it is worth it or is it just pipe and a tip trying to pass as an exhuast setup.
Rolling Big Power DPF-back exhuast set up
Old Jan 11, 2008 | 05:04 PM
surf_ox's Avatar
surf_ox
The DPF gets all the bad stuff out of the exhaust...so the muffler is just done away with
straight pipes after the DPF
it would eliminate some restriction
sounds like it might work
Old Jan 12, 2008 | 12:38 AM
RedDragon777
ok now this has turned into the question of will any DPF back systems work on these new trucks. I hear alot of talk about performance but no real awnser to the code dumping question or even code dumping in the future
Old Jan 12, 2008 | 10:06 AM
kawtiper's Avatar
kawtiper
I saw somewhere in the manuals that came with the truck that showed the part of the exhaust that could be changed. it was ok to change the muffler and all the pipe from the DPF back but for some reason it was not ok to remove the tip. All this without affecting the warrantee, and assume no code dumping due to the fact there are no sensors in that portion.
Old Jan 13, 2008 | 12:17 AM
RedDragon777
i still do not understand how the tip effects anything, they it has something to do with lowering EGTs but i do not see how a 5" tip or 4" tip with some cuts in the pipe will do the same thing
Old Jan 13, 2008 | 12:37 AM
pilotshot's Avatar
pilotshot
The rear exhaust tip has the vents to allow cool air to enter the tip due through the vents due to the suction action of the exhaust air passing over the vents. The cool air mixes with the hot exhaust to cool it. The temperature at the DPF can be 1000F during Re-Gen so at the exhaust tip the air is still very hot and may burn someone. The cool outside air comming through the vents will mix and reduce the hot exhaust temperature.
The exhaust tip is an emission item and must not be removed to protect your emissions warranty.
Old Jan 13, 2008 | 12:55 AM
RedDragon777
thank god for bolt on exhuast, going to save me when i get my next inspection on the stang and soon on the truck
