High flow carb?
Old Aug 19, 2000 | 08:15 PM
4294x4's Avatar
4294x4
High flow carb?
What is the highest flowing 2bbl carb that ford used that will fit on a 429 manifold? It would be very helpfull if you could give me the entire model series number. Thanks
Old Aug 8, 2002 | 08:24 PM
mike460's Avatar
mike460
High flow carb?
the highest flowing 2 barrel i know of still isnt as big as a small 4 barrel(around 500 cfm). in my opinion you should just convert to 4 barrel. just my two cents though.
mike
Old Aug 9, 2002 | 08:17 AM
georgedavila's Avatar
georgedavila
High flow carb?
A conservative calculation says your 429 at 4500rpms needs a minimum of 550cfm at 85% efficiency. A 600cfm 4-barrel would be your best choice.
Old Aug 22, 2002 | 12:45 AM
gray79f250's Avatar
gray79f250
High flow carb?
Old Aug 22, 2002 | 10:16 PM
LxMan1's Avatar
LxMan1
High flow carb?
Holley makes a manual choke 500 cfm 2bbl. It is used by many roundy round racers that have to run 2bbls. They are designed like the front 1/2 of a regular Holley 4bbl. Would probably alot cheaper than a intake and carb. It would be good for a stock engine that isn't going to be turning much over 4000rpm.
