Solid cam question
Old Aug 21, 2002 | 10:35 PM
LxMan1's Avatar
LxMan1
Solid cam question
Old Aug 23, 2002 | 08:26 PM
phantom429's Avatar
phantom429
Solid cam question
OK tommorow I am goin to order in my cam. However I am stuck between two cams. One is a hydraulic extreme 4x4 cam. But I am also lookin at a solid cam that looks real appealing.
Is anyone using a solid cam? Are there any drawbacks besides to occasional adjustment? How are they for power? Any feedback would be greatly appreciated.
Nick from the frozen north
1974 F-250 4X4
soon to be 429
dana 60 front and rear
Old Aug 24, 2002 | 08:11 AM
georgedavila's Avatar
georgedavila
Solid cam question
I've used them in several engines. They do require an adjustable valve train. Preferably roller rockers, but you can use the '68-71 rail rocker set-up with aftermarket lock nuts if you're not going to exceed 5500rpm. Once you get the valve lash set, they require no more maintenance than adjusting the preload on hydraulic lifters, something most people neglect. Should be worth 30hp over the same grind specs using hydraulic lifters.
Old Aug 24, 2002 | 02:00 PM
phantom429's Avatar
phantom429
Solid cam question
Thanks George. I went out and shelled out $220 canadian for a spankin new solid cam. Should be here in 10 days via freight. In case anyone is wondering it is the first cam on the list in comps catalogue. .540 lift, square pattern cam. And I am going to use magnum rollers, with new screw in studs.
1974 F-250 4X4
soon to be 429
Old Aug 25, 2002 | 09:22 AM
georgedavila
Solid cam question
Any particular reason you went with square duration instead of a dual pattern favoring the exhaust?
Old Aug 25, 2002 | 05:34 PM
phantom429's Avatar
phantom429
Solid cam question
Well, as I mentiond in another thread, I am having the heads ported to 200cfm on the exhuast side. I decided to try a square pattern cam, as the dual pattern was no longer as important.
1974 F-250 4X4
soon to be 429
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
