1978 - 1996 Big Bronco
electrical problem ?
Old Jan 10, 2008 | 03:58 PM
midnightrider's Avatar
midnightrider
for some reason my turn signals and low beams don't work, but my high beams & 4 way flashers do. what might the problem be ?
Old Jan 10, 2008 | 07:46 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Midnightrider, I assume this is on your 90?
If you have a multifunction switch on a 90 (dimmer, turn indicators, wiper), then I'd suspect it as being bad. They're easy to replace if that's it.....
Old Jan 11, 2008 | 08:00 AM
helirich's Avatar
helirich
I suspect it's two problems. Start with fuses and then on to the switches. (steering coullom and floor) My 90' doesnt have a dimmer on the wheel. (At least I dont think it does)
Old Jan 20, 2008 | 12:38 AM
Surge08's Avatar
Surge08
the M/F switch was not interduced until 92 when the body style had changed
Old Jan 20, 2008 | 09:10 AM
slickerthanyou's Avatar
slickerthanyou
Could be two different problems, The lights- possible the switch in the dash easy to replace, the turns, could be the switch assembly in the sterring column PITA. I don't have the wiring diagram in front of me. I can't see them being connected but have been wrong before.-Bob
Old Jan 20, 2008 | 12:17 PM
Surge08's Avatar
Surge08
I do own a electrical book by ford for the 88 Bronco if that can be any help
83FordPdx
Mar 9, 2025 02:43 PM
88_F0RD
Dec 30, 2016 12:37 PM
bucktheworld
WTB - Parts & other
Jun 29, 2016 11:37 PM
DaMonsterMonster
Nov 29, 2015 08:23 PM
elyons1970
Apr 25, 2011 01:41 AM
