1978 - 1996 Big Bronco
Front Hub
Old Jan 10, 2008 | 05:53 AM
wetneck's Avatar
wetneck
Front Hub
my fromt left hub is spitting bearing grease out on rim...is this just a simple seal fix?
Old Jan 10, 2008 | 11:00 AM
blue beast's Avatar
blue beast
It could be if the thing hasn't been relubed that the grease lost it's ability to keep
the oil in the grease when it cools down!! Grease is nothing more than a carrier for
oil. I would take it apart and regrease you could replace the o rings but it isn't
needed if the grease is more than a few years old it is just dropping the oil. Don't
take this as a ohh don't worry response you definately need to regrease since the
grease now is nothing but the carrier matrix, If it's a DD and you get on the highway
and or high speeds you are flirting with disaster as MH would say!!
Old Jan 10, 2008 | 11:30 AM
bertha66's Avatar
bertha66
I go with what blue beast is saying, also look to see if you have a o-ring seal on the hub, my 80 does.
Old Jan 10, 2008 | 05:21 PM
wetneck's Avatar
wetneck
i assume there is no fitting and it must be done by hand? then....should i clean it all out and replace all grease? sorry ive just never done one of these before...
Old Jan 10, 2008 | 06:08 PM
redneckbigrigcowboy's Avatar
redneckbigrigcowboy
yep thats a good idea...
Old Jan 10, 2008 | 07:15 PM
93Mule's Avatar
93Mule
I think you are saying that your wheel seal is leaking.
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=NOS&PartNumber= 24917&Description=Wheel+Seal+-+Front+Wheel
I agree with Blue Beast. I had the passenger side inner bearing seize up on me on the freeway. Both caliper pins blew out and the rotor / hub assembly came off the spindle. I was lucky enough to limp into the Holiday Inn parking lot and have AAA tow me home. Pulling the hub apart, changing the bearings, and repacking them with some good synthetic grease will possibly save you some greif. It's routine maintenace and easy to do...
Old Jan 11, 2008 | 07:52 AM
helirich's Avatar
helirich
I think he's saying its seaping out the lockout hub and makeing the wheel dirty. You can take off the hub and put some sylicone on the o-ring. Most hubs leak a little. The best answer is to get the crome sleeves that go out far enough to catch the grease so it doesnt get on the wheel. Of course, if its leaking alot, you need to follow the advice above. Doing it on the highway is no fun.
