Coolant leak
Old Jan 8, 2008 | 07:32 PM
UT1Rusty's Avatar
UT1Rusty
Coolant leak
I just noticed I have a small coolant leak. I have coolant on the bottom of my powerstearing pump and the right/bottom of my motor. I check the pump but it is dry and the wetness starts just to the right mostly by the engin ground steering gearbox and powerstearing pump. I also checked all the plumbing for the coolant and nothing. I see a plug just above what I think are fuel lines right by the ground. Is this a coolant plug of some sort?
Old Jan 8, 2008 | 08:08 PM
Uzumati's Avatar
Uzumati
did you check the weep hole very closely if its only weeping a small amount it will get thrown to the right side of the motor (looking at it) . another spot is the lower extension gasket where the lower hose connects.
Talyn
20
Apr 3, 2013 08:14 AM
AKsnow93
1978 - 1996 Big Bronco
Apr 15, 2011 01:59 AM
danny_g_76
Apr 19, 2007 08:32 AM
1994_ranger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 26, 2006 11:42 PM
Hammerhead
Aerostar
Feb 11, 2004 08:24 PM
