Sponsored by: Real Truck
4x4 question
Old Jan 8, 2008 | 04:49 PM
FORDSDOWNER's Avatar
FORDSDOWNER
4x4 question
Why is it when the my truck is in 4x4 and I turn the wheels it feels like the front end is hopping? Turning right or left and on level ground, it doesnt matter. Hope this is normal. If so, sorry for the newb question.
Old Jan 8, 2008 | 04:54 PM
05pstroke's Avatar
05pstroke
normal...that's how I check mine is working properly.
Old Jan 8, 2008 | 04:57 PM
2000silverbullet's Avatar
2000silverbullet
What kind of surface are you driving on? If it's on a hard dry surface, that's expected of the system as you're causing it to bind.
I would suggest not driving it like that as you're gonna end up breakin' parts... Save the wheeling for off-road (ie, anything but a hard dry surface). You can use the 4x4 on asphalt/concrete if needed when heavy raining/snowing/icy conditions but otherwise, when it's dry, LEAVE IT OFF.
FORDSDOWNER
Cool. I've never steering locked my wheels during 4x4. Would the hopping get a lot worse if I did? Not gonna break anything eh?
Old Jan 8, 2008 | 05:02 PM
FORDSDOWNER
I was coming off of a rocky dirt road with some steep slopes where there was minimum slippage. After I dis-engaged 4x4 hi (light off), I could still feel the bind but it was gone shortly after. I wouldnt drive it like that, it's not practical.
Old Jan 8, 2008 | 05:13 PM
redford's Avatar
redford
FTE Leadership Emeritus
The binding is normal and will not hurt anything, as long as you don't make a habit of it. Turning the wheel in full lock can overheat the power steering pump, plus I'm sure you'd wear something out in the front end if you cranked it over full lock and held it there for an hour while driving in slow circles.....although I'd probably puke first.
Old Jan 8, 2008 | 05:54 PM
FORDSDOWNER
You'd puke first. I dont think so lol
From what I know, holding the steering wheel in a full lock position for longer than 12 SECONDS is a very bad thing. Thats another habit I'm not into......but da wife!!!
