I have a problem with my 02 7.3 that has me and my local shop stumped....hope you guys can help;
Afterleaving my truck for 3 weeks in sub zero deg C temps it started up surprisingly quick with little or no stumbling usually associated with cold weather start ups and then died after 5 minutes. It now won't start at all or for only a short period of time. The codes point to the injection control module but replacing that makes no difference. The CPS has been replaced and that code went away. Once ot twice it has started but only runs for a minute or two before abruptly stopping...almost like turning off the ignition. All electrical connections have been checked, fuel pump is pumping ok, new fuel filter installed and Edge chip has been removed. batteries are charged.
Any suggestions would sure be helpful in solving this mystery. My last resort is to tale it to my Ford dealer along with a blank check.
Are you running an anti gel additive in the fuel, could the fuel be gelled in the tank. What oil are you running. Check under neath valve covers and make sure the 9-pin connector is seated and locked. also check your under valve cover injector clips and make sure the are seated .
By Injection control module do you mean IDM(injector driver module, Computer located behind the drives side fender) or the ICP(injection control pressure sensor, located on the drivers head , valley side with a three wire connector going into it?)
Does it blow any fuses?. possibly #30. if so this is due to the fuel bowl heater grounding out. disconnect plug on back of fuel bowl, replace fuse, start truck.
dump some diesel 911 in the tank, and see if it gets better. I went thru this problem last year for over a month thinking(my fuel can't gel or wax up i use anti-gel, i was wrong).
Ya im in detroit and damn does that fuel gel quickly even with anti-gel - i always carry a bottle of 911 with me.
Goodluck with your problem, Hopefully its just geling!
I'll check under valve covers. Using Diesel Kleen anti gel.Yes I mean IDM....replaced it with no change resulting. Thanks for the suggestions. Truck is at room temp inside shop.
Im having a problem with my truck starting up now to,its been 8 below at night then warms up to around mid 20s or so,i start my 7.3 stroker and it starts good unplugged and runs good but it died this morning while warming up then it started rite back up but soon as i went to town i shut it off and it wouldn't stay running after starting it up at the store,it had been running for about 20 mins by this time,i do run diesel kleen in it for gelling,it would just start and run a sec and die,it would run longer sometimes then die,then i let it sit for about 5 mins while check for blown fusses and it fired rite up and ran good,i also checked the fuel filter housing it was about 1 inch down on fuel,do any of you think my fuel is gelling up on me or maybe my fuel pump is going out?i had to change out my cps the other day to it went out on me,so its good hahaha
