Sponsored by: Real Truck
Header bolt torque
Old Jan 8, 2008 | 10:48 AM
trucksandquads's Avatar
trucksandquads
Header bolt torque
I have a F-250 Super Duty with a V-10. I put a Borla exhaust on approx. one year ago. The exhaust has a leak on the rear driver side. I have new gaskets but am not sure about the bolt torque. Per Borla, they say I am to use factory specs. The problem there is that factory specs are for studs and nuts. I do not have the manual in front of me right now, but believe the torque was 18ft lb for the studs which is what I used for the Borla. This seemed to low the first time I torqued (and re-torqued) the bolts. Is there a better or higher torque for the header?
