Which one should I get?
Old Jan 10, 2008 | 07:10 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
If I'm correct, the stock head bolts on the 6.0 are torque to yield bolts. As a result they would be replaced as normal procedure on any head removal/replacement procedure. Since the head flatness checked out, the HG issue could have been a bad gasket itself, improperly torqued head bolts, stretched head bolts due to over-exuberant use of a tuner, or excess turbo pressure from stuck vanes in the turbo. I'm there are other potential causes but those are the ones that come to mind. Who knows.
However, if it was properly diagnosed and properly repaired then it's probably okay.
Last edited by Powerstroke_wannabe; Jan 10, 2008 at 07:13 PM. Reason: Add additional information.
Old Jan 14, 2008 | 07:22 AM
Baywatch13's Avatar
Baywatch13
Thanks everyone for the input. As an update, I went to look at the '05 mentioned above and found it to be significantly modified. Just as luck would have it though, they had another '05 (F250, 4x4, CC, LB, Lariat, 6.0L diesel) with only 15K miles on it. After some wheel'n & deal'n we finally came to an agreement and I drove it home. I gotta say from first impressions, this thing is awesome! The power difference in the diesel and my old 5.4l gas motor is unbelievable, not to mention the ride and handling difference in the '05 vs. my old '01. I'll miss my '01, but I'm looking forward to alot of good years with this truck. Now I've just got to do alot of reading to learn everything I can about this motor. Thanks again, and I'm sure you all will be seeing me post alot more in this forumn.
Old Jan 14, 2008 | 12:26 PM
IHbase's Avatar
IHbase
No question about it- all things being equal, buy the 05 instead of the 04- not because of the engine, but because the front axle is a much much better set-up. Search the site for additional upgrades from 04 - 05.
-mike
Old Jan 14, 2008 | 04:39 PM
walrus's Avatar
walrus
Congrats on the new truck, Baywatch113.
Old Jan 14, 2008 | 06:55 PM
nitrogen's Avatar
nitrogen
also congratulations,, for NOT buying the other 05, heavily modded, pressure in degas could be heads or egr cooler and oil cooler sounds like problems for some poor sob off warranty
Old Jan 14, 2008 | 09:12 PM
fomoconut's Avatar
fomoconut
Congrats on the new rig. (I sometimes wish I held out for an 05')
gddyup
Jan 10, 2012 08:48 AM
jantman
6.4L Power Stroke Diesel
27
Aug 6, 2010 07:46 AM
cdrmotorsports
May 9, 2007 03:09 PM
steve81
General Diesel Discussion
26
Jun 26, 2006 08:11 PM
tch777
Mar 3, 2002 10:22 AM
