Harmonic Balancer
Old Oct 4, 2002 | 08:32 PM
gray79f250's Avatar
gray79f250
Harmonic Balancer
Is it ok to use a 460 balancer and pulley on a 429 aslong as its from an internal balance 460. Id like to use it since it sticks out farther and works with my already made brackets and pulley setup. Thanks Andy
Old Oct 4, 2002 | 09:13 PM
Ford79's Avatar
Ford79
Harmonic Balancer
It should work fine. I believe the balancers are the same. The difference between an internal balanced and external balanced engine is the spacer behind the balancer. Internal balanced has no counterweight and external balanced has a counterweighted spacer.
Old Oct 4, 2002 | 09:35 PM
gray79f250's Avatar
gray79f250
Harmonic Balancer
Thanks ford79 I thought it would just wanted to make sure before I got to many miles on it.
Old Oct 5, 2002 | 09:18 AM
mike460's Avatar
mike460
Harmonic Balancer
