Truck wont move
Old Jan 7, 2008 | 07:03 PM
scrapyardking's Avatar
scrapyardking
Truck wont move
Just got my '86 F-150 auto, to run after it has been sitting for a year started it up put it into drive and nothing happens it doesnt even try to move. Checked the tranny fluid and its full.
Cant find a vacume hose going to the tranny.
Where would the vacume hose go into the tranny at because I cant find it?
Is there anything else that could cause this?
Thanks
Old Jan 7, 2008 | 08:01 PM
chrisf250-460's Avatar
chrisf250-460
the brakes could be frozen.the vacuum line goes into the modulator valve on the back of the transmission ,should come from vacuum tree on intake
Old Jan 7, 2008 | 08:06 PM
Franklin2's Avatar
Franklin2
It also depends on what model tranny you have. An AOD does not have a vacuum line, it uses a cable on the throttle to control the tranny. Make sure you try all the tranny selector positions.
Old Jan 7, 2008 | 11:21 PM
scrapyardking
Im retarded the transfer case was in nutral.
Sorry to wast your time
Old Jan 8, 2008 | 09:54 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Hey at least it wasnt something expensive, now it'll just cost you a 6 pack while you sit back and laugh about it.
Old Jan 8, 2008 | 02:02 PM
boggerted's Avatar
boggerted
HAHAHAHAHAHAHAHAHAHAHA...sorry had to laugh
