engine dies while driving
Old Jan 7, 2008 | 10:24 AM
dps72f-100's Avatar
dps72f-100
I have a 2003 Crew Cab 4X4 with a 7.3. When cruising down the road the engine will die. Sometimes it will come right back, but sometimes I have to pull over and turn off the ignition and restart it. Any ideas?
Old Jan 7, 2008 | 10:33 AM
F350-6's Avatar
F350-6
Without more information, history or symptoms I'd guess a faulty CPS. If you still have the factory CPS it is currently under recall. If not they're less than $30 at Ford (don't buy from the auto parts store).
A link on how to change is here: http://guzzle.rbmicro.com/cps.html
Old Jan 7, 2008 | 11:08 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I agree with Chris, CPS.
Old Jan 7, 2008 | 11:17 AM
dps72f-100's Avatar
dps72f-100
Thanks for the response. The truck has 73,000 miles and the CPS has never been changed. I thought, from what I had read and heard in the past, that this might be the problem. I have a spare CPS, but I did not want to change it without being pretty sure this was the problem.
Old Jan 7, 2008 | 04:50 PM
clintbonnie's Avatar
clintbonnie
If your spare is black and not grey, i would let the dealer replace the cps with the new design grey one.. no charge .. on a recall..
Old Jan 7, 2008 | 06:34 PM
dieselboy3278's Avatar
dieselboy3278
chafed wire's
had kind of the same problem when i would get the truck to about 70 it would die let of the pedle it would come back to life
found out there where some bare wire's to the cam sensor fixed the wire's and it hasent done it for three year's
