370 Timing Specs
Old 10-15-2002, 04:36 PM
phasers's Avatar
phasers
phasers is offline
Post 370 Timing Specs
I have a 1986 F800 with the 370 V8, California engine. I'm trying to time the engine but I'm confused about the timing order and cylinder identification.
The book says Right bank 1-2-3-4, Left bank 5-6-7-8, firing order is 1-5-4-2-6-3-7-8, distributor rotates counterclockwise.
The confusing part is the intake manifold is cast with cylinder numbers on the runners at the intake ports but they are opposite of the above.
Are the cylinders ID'd looking at the engine over the grill, drivers side is right, pass side left, or from behind pass is right and drivers side is left?
I've tried different methods to time it, but until I know WHERE number 1 is, I'm stuck.
I have spark and fuel but no fire. Not even a pop.
phasers
Old 10-15-2002, 11:06 PM
merc460's Avatar
merc460
merc460 is offline
370 Timing Specs
the #1 cyl is on the right from the drivers seat and it is the cyl closes to the rad or the #1 cyl on the right side Eric
Old 10-16-2002, 08:25 PM
phantom429's Avatar
phantom429
phantom429 is offline
370 Timing Specs
If you look at the front of the engine, the head on the passenger side of the car is further ahead of the one on the drivers side. The first plug on the passenger side head is #1.
Nick from the frozen north
1974 F-250 4X4
soon to be 429
dana 60 front and rear
Old 10-16-2002, 08:31 PM
reddogracing's Avatar
reddogracing
reddogracing is offline
370 Timing Specs
macubus
2004 - 2008 F150
08-03-2019 01:03 PM
dexterslab724
2004 - 2008 F150
08-12-2017 12:51 PM
Wildboy402
2004 - 2008 F150
12-24-2015 12:42 AM
MikeH52164
2004 - 2008 F150
03-12-2010 07:57 PM
signalius
01-16-2004 06:17 PM
Quick Reply: 370 Timing Specs
