signal lights shorted out?
Old Jan 6, 2008 | 09:20 PM
justin_jkj's Avatar
justin_jkj
ok i have an 89 ford f150 and a little while ago i noticed that whenever i put the brakes on at night the gauges and park lights would come on a little bit but now my left signal light wont work, it comes on and stays on but the right one works normal. anyone have any ideas? thanks
Old Jan 7, 2008 | 04:25 AM
mjlimo82's Avatar
mjlimo82
Is it wired for trailer lights? If it is you might check the wiring to see if there's an open ground somewhere. Look for any wires that have the insulation rubbed off, or bad connections. Thats my guess... I haven't had this bodystyle truck in 5 years so maybe someone more familiar with these can help you more if that's not it! Good luck.
Old Jan 7, 2008 | 10:19 AM
jmd1's Avatar
jmd1
try new tailite bulbs. if one of the filaments brake and lay against the other filament power feeds in backwards directions.
