5.8L EFI Engine tick?
Old Jan 6, 2008 | 05:49 PM
ford5.8's Avatar
ford5.8
My 96 F150 5.8L recently aquired a tick coming from the right side of the engine. So I thought for sure it was a exhaust leak,but there is no leak and it only makes the tick when the engine is under load. For example reving it in nuteral you can hardly hear it,but if you put it in drive and apply the brake/gas you can hear it tick pretty good. What would make my engine tick only under load? A piston pin or rod bearing? If it is a exhaust leak I would think it would do it all the time.
Old Jan 6, 2008 | 06:00 PM
Conanski's Avatar
Conanski
Honestly.. that sounds more like and exhaust leak, there's a lot more pressure behind the exhaust when the vehicle is under load, so it would be louder. Check the air injection system and EGR plumbing as well as the manifold to Y-pipe connection.
Buck268
2009 - 2014 F150
Nov 21, 2014 03:53 PM
kij150
Oct 7, 2013 05:59 AM
CJN
1997 - 2003 F150
24
May 10, 2010 09:03 PM
19952X250
Jun 17, 2005 10:27 PM
seebeew
Exhaust Systems
Sep 5, 2001 03:36 AM
