block and head casting #
Old Oct 17, 2002 | 07:12 PM
georgedavila's Avatar
georgedavila
Old Oct 18, 2002 | 10:54 AM
meter099's Avatar
meter099
could you please tell me what block and heads i have 460 block # d1ve-6015-a2b head # d3ve-a2a are they any good? would the timing gears be straight up or offset 8 degrees thanks for your help
Old Oct 20, 2002 | 12:43 AM
LxMan1's Avatar
LxMan1
The heads are a 73 or later casting, the block is a 71 casting. I would say that it is a good lower compression motor. If it is all original, then it is at least a 73 and would have the 4 degree retard built into the timing gears.
