94 fordf-150
Old Jan 6, 2008 | 02:45 PM
fordf-15094's Avatar
fordf-15094
94 fordf-150
My 1994 Ford F-150 Came With A Factory 300 I6 ,5speed Trans .,works Perfect It's Got All The Power ,with 178,000 Miles On It ,is A Perfect Truck My Question Is; Is It Posible To Install A Automatic Transmision On It Whit The Same Motor ?
Old Jan 6, 2008 | 04:47 PM
ford_boy_1996's Avatar
ford_boy_1996
Yes it can be done but...It matters what automatic trans you use
Old Jan 6, 2008 | 07:44 PM
fordf-15094
any body have done it,
Old Jan 7, 2008 | 08:35 AM
Kemicalburns's Avatar
Kemicalburns
with a 94 your options are C6 or E4OD. the E4od would give you an OD gear but require you to locate the proper wiring harness. this shouldnt be hard though it was a common option.
