Gas Tank Valve
Old Jan 6, 2008 | 12:25 PM
jthomp03's Avatar
jthomp03
Gas Tank Valve
I'm replacing the two tanks on a 1979 F350 4x4 with a single rear mounted 38gal
tank and need some info on simplifying the emission and fuel tubing. The manual lists a 9F271 valve and solenoid mounted in front of the rear tank, can I eliminate this? And I can lose one of the charcoal canisters I would assume, am I missing anything that will keep the truck from running and passing the Calif smog test? Also the 98076 valve assembly on the top of the tank, is that the rollover protection or....And where can I get a new one? Thanks......
