93 explorer limited Edition PROBLEMS
Old Jan 6, 2008 | 11:35 AM
trucks967's Avatar
trucks967
Question 93 explorer limited Edition PROBLEMS
When I start my expl my headlights start flashing and theres a clicking noise and everything is flickering inside and when I shut it off it stops and it's not the battery because I just replaced it confused ?
Old Jan 6, 2008 | 02:52 PM
aquanaut20's Avatar
aquanaut20
Find the source of the "Clicking" probably a relay, this will isolate the area to troubleshoot
Old Jan 6, 2008 | 03:55 PM
MCDT's Avatar
MCDT
Had a similar problem on a 97 Ranger. Turns out an aftermarket trailer wiring connector, the kind that just plugs in malfunctioned and was creating all kinds of feedback through the electronics.
Old Jan 6, 2008 | 05:29 PM
mrshorty's Avatar
mrshorty
How about bad cables??
Old Jan 6, 2008 | 07:28 PM
trucks967's Avatar
trucks967
Well my battery did die and checked alt and it is good so replaced battery cables are good thanks for repling and I 'll check the trailer connector also but this all started when I replaced the battery . ???
Old Jan 11, 2008 | 06:38 PM
BobD2655's Avatar
BobD2655
Check all ground return lines from body to battery. (Not just engine block to battery)
