1970 460 into a 1984 truck with a hydraulic 4spd manual?
Has any one else done this swap? So far I am using a 390 flywheel redrilled for a 86 460 12" clutch with the hydraulic bellhousing. The only problem I can see is that the flywheel thickness between the internally balanced and externally balanced are different. The externally one seems a little thicker. Will that interfer with the clutch disengaging?
Thanks for your replies,
Craig
Craig
