New Tranny
Old Jan 5, 2008 | 04:15 PM
Learath's Avatar
Learath
New Tranny
ok finnaly have a good tranny to put in my truck, i might actually be able to use the thing finally.
anyway i want to install a temp gauge in the tranny and im not sure if i want to put it in the pan or the line coming out of the tranny. its a c6 and freshly remanufatured. does the c6 have a thermostat of any kind in it? this is a reason i have gone with a gauge in the past. i had a friends car the electric thermostat in the tranny just stopped one night and the whole thing melted. so in the pan and if something like that starts to happen i would know. however the fluid out would be the hottest and give me a faster reading. any ideas? what have you done? which line on the c6 is the out and which is the in? what is a normal cruising temp for these?
Old Jan 5, 2008 | 09:38 PM
ford trans tech's Avatar
ford trans tech
there is no thermostat in a c-6 the line at the front of the trans is the outlet and basically putting a sensor in the pan is usless because the fluid there is the coldest the outlet line will give the correct temp reading
Old Jan 5, 2008 | 10:47 PM
Learath's Avatar
Learath
exelent thank you.
Bootlegger's Deluxe
Nov 29, 2012 12:18 AM
buffalobob
Nov 21, 2007 11:32 AM
fasthauler
20
Jul 2, 2007 12:24 PM
fasthauler
May 31, 2007 01:03 AM
PHetrick
1978 - 1996 Big Bronco
Feb 26, 2006 03:41 PM
