Sponsored by: Kumho
drum problem
Old Jan 5, 2008 | 02:40 PM
F250DUDE66's Avatar
F250DUDE66
drum problem
hey i have a 78 150 and i cannot get the drums off now i saw in the haynes that i have to move the adjuster i did but now for somereason it seperated and is on the bottom of the drum so i can not adjust it how should i get the drum off it seems stuck on there thanks
Old Jan 5, 2008 | 03:20 PM
merlynr's Avatar
merlynr
If you can turn the drum by hand then it's probably stuck on the axle flange. If a couple of big screwdrivers in the back does'nt do it, you may need to get a 2 lb hammer and hit the front edge of the drum at a 45 degree angle at different spots around the edge. Heat is always good around the flange area.
Old Jan 5, 2008 | 03:31 PM
F250DUDE66's Avatar
F250DUDE66
hahahaha
wow 4 times and boom
right off
after 2 hrs of prying i just had to hit it in the right spot
thanks i appreciate it
