Trans too cold?
Old Jan 5, 2008 | 04:11 AM
mjsparky363's Avatar
mjsparky363
Trans too cold?
Good morning all. I've searched but to no avail. This summer I added a Derale trans cooler with a fan in-line with the factory tow package cooler. Now that the weather is much colder, I am getting the dreaded "clunk" when I let off the gas and coast down. If I lock out the OD it doesn't do it. Since this started this year(truck is 2004/65000mi.) could it be the fluid temp is just too cold? I was told once that there is a by-pass block (right by the trans) that shunts the fluid in a closed loop until it reached 180 deg. but I have a gauge with the sender in the test port and I'm not getting above 140-145. Or is this the slip yoke problem and just happened now to rear it's ugly head? Thanks for any replys.
Old Jan 5, 2008 | 04:43 AM
phil6608's Avatar
phil6608
If your seeing 140 to 145 that's a good temp range. Should be plenty warm enough.
If you want it a little warmer,,,unhook the fan on it.
I would look elsewhere for the clunk problem.
Old Jan 5, 2008 | 05:18 PM
deisele75's Avatar
deisele75
Unlike an engine, a transmission works best when cold.
