Flywheel Question
Old Jan 5, 2008 | 12:02 AM
KD4PWH's Avatar
KD4PWH
Question Flywheel Question
I'm doing a clutch replacement on my 99 Ranger SuperCab 3.0 4x4 155,000 mi. and I have few questions for the crew.
1. Can the flywheel be machined, or is it a tapered (concave) design that requires replacement?
2. Does anyone know the resistance values that the O2 sensors should meet? I would like to ohm them out before replacing all three.
Thanks
Chris
Old Jan 5, 2008 | 05:14 AM
Pablo-UA's Avatar
Pablo-UA
__________________________________________________ ________________
It is worn with clutch disk, but usually no reason to replace it if it is not concave for less then 2-3 mm.
Old Jan 5, 2008 | 10:05 AM
Rangerman Stan's Avatar
Rangerman Stan
KD4WPH, yes the flywheel should be able to be machined if it's uneven or has ridges. Just to make sure, contact an automotive machine shop in your area about this. I don't think they've changed to the point yet where they're just throw aways. Sounds like it would also be a good time to put a new pilot bushing in the crank for the transmission input shaft. When installing the flywheel onto the crank, if you can't get the second or third bolt started because the holes don't seem to be lined up, it's because they aren't. Some engines have the bolt hole spacing off set so the flywheel balance pad will line up correctly with the crankshaft to keep the factory balance in place. So you may need to rotate the flywheel to a different hole or two on the crank to get them to line up. I'm not exactly sure if this applies to your engine or not but it's something to keep in mind. Have fun and let us know how it goes. Sorry, I'm not sure about those resistance values.
Old Jan 5, 2008 | 10:41 AM
customstringer's Avatar
customstringer
It is commonly advocated here that if you are doing the clutch job to also replace the slave cylinder while you are in there-prevent a future headache. Consider replacing the rubber shift rail plugs. I believe some even say to replace them with metal ones if you can get ones to fit.
Old Jan 5, 2008 | 11:55 AM
KD4PWH's Avatar
KD4PWH
Using a machined straight edge, the flywheel was about .004"" tapered to the inside. I went ahead and just bought a new one. I'm also replacing the slave cylinder as well.
I finally got the pilot bearing out with a cold chisel and a lot of pounding. The new one has a rubber seal in it on one edge....does anyone know which way to install it? With the seal toward the crank, or tranny?
Thanks for all the replies!
Chris
estwing17
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 21, 2008 12:14 AM
beekermartin
1997 - 2003 F150
Jan 14, 2007 12:28 PM
hood
3.0L V6
Dec 30, 2005 08:58 AM
guitarman 39
Aug 12, 2004 04:09 AM
jeff21876
Apr 25, 2001 09:15 PM
