Frame rot
Old Jan 4, 2008 | 07:11 PM
oscarxyz's Avatar
oscarxyz
Frame rot
Took the bed off the 60 and found a weakened frame.
Surprise and dismay. The passenger side rail behind the cab looks bad.
Notice the mount is partially eaten away.
Also, those two small dark patches on top of the rail are indeed holes eaten all the way through.
Drivers side sure looks good though.
What is the right way to fix this little problem?
Old Jan 4, 2008 | 07:50 PM
vintage56's Avatar
vintage56
easy - donor frame
hard - cut out and replace.
JML
Old Jan 4, 2008 | 08:20 PM
49fordpickumup's Avatar
49fordpickumup
Frame
Monitor craigslist.com for what you need, also Show Me 100's club in Springfield, Mo may be able to help. There are others here that can tell you what years that covers the frames that are the same as yours and the best way to cut and weld the repair if you chose that direction.Have a great day, chuck
Old Jan 4, 2008 | 09:55 PM
oscarxyz's Avatar
oscarxyz
I went out last fall looking for a bed and brought home a whole truck. Looks like I need to take a closer look at that spare truck.
Granted I am pretty new to this stuff, but I would have thought a cut/patch/weld to the frame would be easier then pulling everything off and putting it on a different frame.
Of course my thought has not been a frame off restoration, but a cleaned up daily driver.
Old Jan 4, 2008 | 11:05 PM
CharlieLed's Avatar
CharlieLed
I think that you will find that it's not that big of a job removing the cab/bed/front end off a frame. You wouldn't be the first among us to start out a "wash & wax" project and end up with a frame-off restoration!
Old Jan 5, 2008 | 01:32 AM
vintage56's Avatar
vintage56
my frame off started w/ a blown head gasket, ha!
transferring bodies truck to truck could be a weekend task
JML
vintage56's Avatar
vintage56
oh, and do look up those show-me guys. good bunch from all I've seen and heard.
JML
Old Jan 5, 2008 | 01:28 PM
bigwin56f100's Avatar
bigwin56f100
Short be or long bed frame? I have a 59 or 60 long bed frame that is in EXCELLENT condition. Frame only with all cross members and spring mounts $200 in Akron Ohio. Let me know.
Kevin Bigwin
