electrical problem. help!
Old Jan 4, 2008 | 05:06 PM
Ranger73's Avatar
Ranger73
ok,
turn signals dont work but hazards do, so i replaced flasher.....no help.
right rear light goes on but brake fillament doesnt light up.
i changed the socket and no help. (new bulbs too)
after changing socket none of the turn signals work and brake light still no good.
what is my problem?
Thanks in advance. -Pete
thinking of geting a new wiring harness, which company makes a complete harness, inside, engine compartment, and lights? the electrical system on this truck is killing me!!!!!!!!!!
Old Jan 4, 2008 | 05:55 PM
brownfoot's Avatar
brownfoot
you haven't dug deep enough
do you have good grounds in the rear? a little rust is all it takes, remove and clean them
could be a problem with the T/S switch, they're prone to failure
you didn't mention, are the front signals working?
Old Jan 4, 2008 | 06:11 PM
Mil1ion's Avatar
Mil1ion
Which flasher did you chnage Hazard or the one for the T/S 's ?
I suspect you have a Turn signal switch problem.
First make sure all the ground wires at bulb locations have good ground.
Old Jan 4, 2008 | 06:25 PM
Ranger73's Avatar
Ranger73
fronts arent working.
im pretty sure the grounds are good because i cleaned all the ground wires and painted them a few months ago, but im going to check them.
turn sigal switch sounds complicated, never taken that apart before, i have an idea of what its like but ill have to do some poking.
any one have diagrams?..........
thanks alot guys ill keep posted.
P.S.---any input on new harness.?
-Pete
Old Jan 4, 2008 | 06:44 PM
JBradley500's Avatar
JBradley500
make a ground from the bulbs ground to the truck frame....it will show you if the ground in any of the sockets are bad....i just fixed mine with similar problems as yours. do all of the sockets not just the ones you suspect.
Old Jan 4, 2008 | 06:50 PM
73f100shortbed's Avatar
73f100shortbed
Turnsignal switch is like a bllion times less complicated then putting a new wiring harness. You painted the ground wires? Maybe the paint is not giving you as good of a ground. I had a similiar problem and it was my turnsignal switch. It's easy to replace. I think it took me like 10 minutes to do.
Old Jan 5, 2008 | 09:15 AM
Ranger73's Avatar
Ranger73
im doing a wiring harness regardless, but this is my daily driver so i need to fix it now....heheheheh
gonna check grounds and check for shorts......keep ya posted.
Old Jan 5, 2008 | 09:31 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation Turn signal switch 1973/77 F100/350
1973/77 F100/350
D3TZ13341A .. T/S Switch - 1973/77 - MANUAL Transmission ~ w/o Cruise Control *
D3TZ13341B .. T/S Switch - 1973/77 - AUTOMATIC Transmission ~ w/o Cruise Control *
D5TZ13341B .. T/S Switch - 1975/77 - Use with CRUISE CONTROL only - Obsolete.
* STILL available from Ford.
D3TZ13341A = Ford suggested retail price: $96.00 / FTE member net: $67.85
D3TZ13341B = Ford suggested retail price: $69.98 / FTE member net: $49.46
The above parts prices are from FTE sponsor Direct Ford Parts (Gaudin Ford-Las Vegas, NV)
Their link is on the forum main page - refresh till it appears.
Old Jan 5, 2008 | 06:24 PM
Ranger73's Avatar
Ranger73
thank you very much, my dad brought one home from work from an earlier model, same thing except for display light.
didnt fix the problem.
i cleaned the connections to the actual flasher and nothing.
the turn signals work at some points when i was messing around with the wire so i think its a short somewhere. gonna work with someone on it tommorow and if it doesnt work im gonna order a painless or centech wire harness
