'89 F-350 Electrical Issue...
Old Jan 4, 2008 | 04:35 PM
2002sport's Avatar
2002sport
I got a '89 F-350 with the 7.3 L Diesel. It has an electrical problem, it seems to loose like half it's power. When it happens while I'm going down the road, the temp gauge buries itself up past hot, the volt gauge drops right between the red and white. If I turn the blower on, the gauges, even the tach loses power completly. Right now the truck won't start, I turn on the key and the indicator lights are dim, It won't roll over either, and the horn won't even honk, but you can hear it click when you press it. The Problem is intermitten, I may go out and mess with it a bit and it'll start right up and be fine for a while. Both batteries are good.
