460 probelms
Old Nov 14, 2002 | 09:29 PM
79bigblue's Avatar
79bigblue
460 probelms
I have 79 F 250 4 speed, 460 that I recently rebuilt and just put in the other day. The truck rolls in neutral, and will roll when you push the clutch in. The engine will not roll over. I have tried rolling it over at the crank but it still won't roll over. I have tried pulling the truck and dumping the clutch but the thing wouldn't turn over. The motor is two months old. Any suggestions on a problem or maybe a solution? If the flywheel bolts where 1/8 longer would that cause a problem? I am open to any suggestions.
Thanks
Mike
Old Nov 14, 2002 | 09:39 PM
gray79f250's Avatar
gray79f250
460 probelms
Sounds like you used the wrong pilot bushing. Try and loosen the trans from the bellhousing by about 5/16 of an inch and see if it turns by the starter. This could be the case if its a 4x4 and you just put 460 in if its a 4x2 and it had a 460 I dont know. Keep us posted. If its the 4x4 issue there are ways to fix this.
Old Nov 14, 2002 | 09:52 PM
79bigblue's Avatar
79bigblue
460 probelms
I had the combination working about a month ago, but the teeth on the ring gear came off so I had to replace the ring gear. I finally got to replacing the ring and finally got everything back together but now will not work. So I don't think it could be the pilot bearing. It really started hard before i tore it apart if that means anything.
Mike
Old Nov 14, 2002 | 10:31 PM
LxMan1's Avatar
LxMan1
460 probelms
Is the ring gear too thick and wedging against something? Try removing the starter and see if you can turn the engine then.
Old Nov 14, 2002 | 10:51 PM
gray79f250's Avatar
gray79f250
460 probelms
What combo are you using I have had a 460 and now a 429 in my 79 250 4x4. I had probs starting the 429 but it was my fault for using a standard 429 bushing. Doubt its the bolts either. Did you replace ring gear or the whole flywheel.
Old Nov 14, 2002 | 11:20 PM
79bigblue's Avatar
79bigblue
460 probelms
The ring gear is just new. It is a 429 flywheel actually, but the guys at ford said it will work just fine.
Old Nov 14, 2002 | 11:25 PM
gray79f250's Avatar
gray79f250
460 probelms
Im unsure of the 429 but have been told a 460 flywheel wont clear the webbing in a 351m bell if thats what you have.
Old Nov 14, 2002 | 11:30 PM
79bigblue's Avatar
79bigblue
460 probelms
The 351m bell housing will fit on the back of a 460?
Old Nov 15, 2002 | 02:19 AM
gray79f250's Avatar
gray79f250
460 probelms
[updated:LAST EDITED ON 15-Nov-02 AT 03:20 AM (EST)]Yes thats what I use to but supposedly the webbing inside the bell hits a 460 flywheel if you dont grind itdown some. Someone I know had to grind theres with an l and l flywheel to. Just tryin ti get you some ideas. I would think at this point it couldnt hurt to loosen the bell housing and see if it turns.
Old Nov 15, 2002 | 04:06 AM
mshumack's Avatar
mshumack
460 probelms
Fordfan54
Apr 11, 2014 01:10 PM
Camsdad
Jan 21, 2014 03:40 AM
79fordchick
Feb 19, 2011 07:15 AM
460man
May 14, 2006 01:33 PM
Kendall
2004 - 2008 F150
21
Nov 22, 2004 10:18 AM
