Distributor Gear Problem
Old Nov 13, 2002 | 11:00 AM
Old5's Avatar
Old5
Old Nov 14, 2002 | 06:18 PM
gray79f250's Avatar
gray79f250
I used the dizzy from my 460 in my current 429 the electronic type. I had to pull it out tonight for another reason but the gear is worn very bad and chipped. This worked fine in the 460 with no wear. Is there a reason I cant use a 460 dizzy in a 429? Anyone with an answer or had this happen to them please let me know.
Thanks Alot Andy
Old Nov 15, 2002 | 04:06 AM
mshumack's Avatar
mshumack
429 and 460 are same. Perhaps some trash got in between gears when you installed - or later during running. If you install distributor, you should be able to feel some gear backlash. If not try installing a thicker gasket (or doubling gasket) to pull gear up slightly from full mesh.
