Sponsored by: Real Truck
traction
Old Jan 3, 2008 | 01:59 PM
Jocaren's Avatar
Jocaren
traction
i will be getting a 2wd reg cab 250 soon, i want to know what size and what kind of street tire/rim will be best for traction! this truck will be pushing over 600 by the time its said and done, am i SOL for traction on the street or are there some awesome street tires that i need to know about... Thanks
Old Jan 4, 2008 | 02:16 PM
Jocaren's Avatar
Jocaren
noone has an answer?
Old Jan 4, 2008 | 02:21 PM
CaMo_FroG's Avatar
CaMo_FroG
SLICKS ? ...... ahaha j/k ye man prob just some good cheap all terrains if u go through them fast .... maybe there is some tire guys here ?.....
Old Jan 4, 2008 | 03:21 PM
redford's Avatar
redford
FTE Leadership Emeritus
Are you are looking for strictly a dry traction street tire capable of planing 600 RWHP? Do you plan on towing or hauling a load?
If not, drop down to a Load Range D or even an LT tire, get the widest highway tire you can fit on the rim. Brand and style won't matter much, since you'll be smoking them on a regular basis anyway.
I have in the past seen guys get Dually fenders, then use Mickey Thompson Sportsman S/R tires on wide rims. You can get those as wide as 33X22.00R20, which is one big a$$ tire! I wouldn't want to drive it in the rain, though.
http://www.mickeythompsontires.com/s...em=SportsmanSR
Old Jan 4, 2008 | 03:47 PM
DCSpecial's Avatar
DCSpecial
Link the rear and run some Toyo Proxes ST or Kumho has a similar tire.
They grip pretty well.
Beyond them...street slicks (maybe have the rear shortened if you want real wide)
If I had a 2wd with some hp I'd lower the truck, link the rear and run some nice 22s with either the Toyos or Kumhos. Of course I'd run something like a Trutrac or Detroit in the rear end....
Old Jan 4, 2008 | 05:37 PM
duffman77's Avatar
duffman77
I really regret getting the 18" rims over the 17"s. Less tire selection on 18"s for sure.
Old Jan 4, 2008 | 06:32 PM
NEWT92's Avatar
NEWT92
[QUOTE=redford]Are you are looking for strictly a dry traction street tire capable of planing 600 RWHP? Do you plan on towing or hauling a load?
http://www.mickeythompsontires.com/street.php?item=SportsmanSR[/QUOTE]
Back in 1990 a local GMC dealership had a new GMC half ton reg cab shortbed 2wd, solid maroon with dually fenders and the Mickey Thompsons on and was a sweet looking truck. If you done that, you would have a unique looking truck!
Old Jan 4, 2008 | 06:38 PM
BareBones's Avatar
BareBones
Guess I'm confused. I only have 360 hp and I can't keep the butt on the ground as it is.... At 600 hp you'll be airborne if you hit a pebble in the road............
Old Jan 4, 2008 | 08:02 PM
mitchrock1's Avatar
mitchrock1
You might want to build some custom traction/ladder bars. And don't even think about taking it off the pavement cause you'll be SOL even on wet grass. LOL
Old Jan 4, 2008 | 08:35 PM
bruno6491's Avatar
bruno6491
i have some 305/50/R20 Toyo Proxes ST on my truck. I have a superchips tuner and a 5" cat back exhaust with no cat and i smoke these tires, so you will need something wider for 600hp. They don't let me spin to long but i get them going and probably only at 400 at the wheels, if that
Check the gallery for pics
Bruno
Old Jan 4, 2008 | 08:39 PM
Jocaren's Avatar
Jocaren
the truck already has close to 600 on fuel and 730 on 2 stage nitrous, i will be makinging it a swb instead of lwb, 4 link susp, has detroit locker, slicks and street tires are 11 in wide, just will need more grip, anything past half thottle breaksem loose even at 50 mph!
Old Jan 4, 2008 | 08:43 PM
DCSpecial's Avatar
DCSpecial
Who's truck was it?
Old Jan 4, 2008 | 08:46 PM
someday's Avatar
someday
those mickey tires r remind me of super singles
