well first you need the 429 and the trans ,your c6 behind the 360 wont bolt up to the 429. search this forum for 429 swap youll find lots of info on it
The C6 from a 429/460 Big block or a C6 from an M block will work. Unless you really want the stick with a C6 I would look into an overdrive off a later 460(not an electronic overdrive)
