Vehicle Trailering and Loading
Had a question about trailering cars and trucks. Ive towed almost every load i can think of other then a vehicle. I have a 18' flatbed backhoe (dont have a back Though!) trailer and a 16 ft' flatbed (both dual axle). Some of my questions are - What would be the steps to securing the vehicle? What straps are needed? where do they go?
Also - my trailers do have large heay duty ramps, what would you suggest for a winch? warn seems to be most populer. what weight should i get? I would be towing mostly junk vehicles. Is there an alternative to a winch?
Thanks for the help - basically i need a rundown on trailering a vehicle.
It is also possible to double the force of the winch by using pulleys. An extra pulley added to the mix effectively doubles the force (sorta... if I remember my physics correctly no pully = rated load, 1 pully = 2x load, 2 pulleys = 3x load...) But it takes a lot more time to do the same amount of distance.
Definately overwinch yourself, with a constant duty high quality winch. Warns are one of the staples of the industry as far as quality. There are others as well. Be wary of the cheap ones; they are great for occasional work, but need rest halfway (or less!) through the pull to cool down. I had a 6000lb Chicago Electric on my F150 and it was great for the occasional bout of stupidity, but it was not a work winch. It took a good 15 minutes to pull the full 100ft of cable with very little load. They are dang expensive, that's for sure! I spent $400 on mine brand new, an equivlent Warn would have been $900. You get what you pay for :P
