Sponsored by: Auxito
verification
Old Jan 2, 2008 | 07:21 PM
addicted56's Avatar
addicted56
verification
Hello,
Comming off the classic side to ask a question.
There is a guy local with a rear end from a 98 F-150 4X4 that says he has a Dana 60 from it he is getting rid of.
I'm assuming this is the 9.75" Ford. I haven't asked him if it was the 5.4L but will.
If so am I safe in assuming that it is the 9.75" before I drive over and check it out. Or did they come with a D60.
Also I'm just doing a bit of research here and I did a bit of research but if anyone could throw in the Wheel-to-wheel width of the rear end that would be excellent. I'm assuming these are centered axles like the 60 as I'm wanting to swap it into a FJ40. Should be working on my 56 but ohh well, got to love all the projects.
Thank you,
Jason
Old Jan 2, 2008 | 07:30 PM
addicted56's Avatar
addicted56
Well he just gave me these numbers
top Row 3 S 909 8 1 Bottom Row 3L55 9 75 7M08
So I'm guessing that is a 3.55 rear end 9.75". I'm guessing that is what that means. So hopefully I answered my own question
Guy said it had 3.73 gears so I have to wonder more about it.
So for future info what do the rest of the numbers mean????
Thank you.
Old Jan 2, 2008 | 10:07 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yes, you figured it out. 9.75" axle with 3.55LS gears.
They stopped putting rear D60's in trucks back in the 1970's
Old Jan 2, 2008 | 10:31 PM
addicted56's Avatar
addicted56
Thank you,
Sounds like plenty of axle to put behind my cruiser. Now if I can just find out how economical or easy it is to shorten the WTW to fit the FJ 40.
