Engine oil cleaner?
Old Jan 2, 2008 | 08:33 AM
.:84Ranger:.'s Avatar
.:84Ranger:.
Engine oil cleaner?
Just having picked up a new 08 ranger, I want to keep this engine in prestine condition. All engines have a tendency to get gunked up. I thought sticking to oil changes every 3000 miles would be a good start, and then every 9k miles, running some oil detergent through the engine and then draining it. The user's manual says not to use any type of detergents? I wonder if this is to the detriment or the benefit of the engine. Any enlightened input would be appreciated! Should I use the engine cleaner every 9k miles or not?
Old Jan 2, 2008 | 11:12 AM
wtroger's Avatar
wtroger
Use top quality oil keep it changed somewhere between 3000-5000 miles (use the lower number if mostly urban driving) use good oil filters and Change the Air cleaner regularly and you won't have problems. My 2003 is coming 100,000 miles and the oil is just starting to darken when when I change at 4000 miles.
cmoore's Avatar
cmoore
I would not. If you change your oil every 3000 miles that should be plenty good enough. Your engine will say thank you every time you spin that new oil filter on.
Old Jan 2, 2008 | 09:54 PM
Level2's Avatar
Level2
No need to change that often unless you make short runs and don't get the engine up to a good operating temp. Run the suggested 5W20 weight in the 2.3L and after the first 10K miles I would switch to a good synthetic like Mobil1, Amzoil, or Royal Purple. Run a good filter and change the oil every 5K and everything will be fine. I have the 2.3L in my 2005 Focus and run Mobil1 SuperSyn and change it every 10K miles and no problems so far. Oil comes out pretty clean and the car has 73K on it.
Old Jan 2, 2008 | 10:57 PM
RangerPilot's Avatar
RangerPilot
Sorry this is my chance to rant about the previous owner of my Exploder using Vavoline and 5K oil changes.
DUMB..........insert favorite expletives here...........IDIOT
I'll be running some stuff through the engine for the last 500 miles, then switching to my beloved Mobil 1.
Old Jan 3, 2008 | 08:12 AM
pawpaw's Avatar
pawpaw
IMO, with a crankcase lube that says on the container, that it meets or exceeds Fords 930 specs & doing 3K OCI's, your not likely to need any kind of engine oil additive/detergent/flush, as a fully formulated crankcase lube has all the detergent our engines need.
If your still of a mind to add something anyway, maybe consider something like "AutoRx", which is a ester based cleaner upper, that won't mess with the oils chemistry too much.
But if it were mine, I'd just skip the detergent & use the money on good filters like a Motorcraft & a good oil.
BTW Zach, if your Exploders engine is messed up with deposits & your determined to use something, you might consider the AutoRx too.
